Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Wall sections
12 REPLIES 12
Message 1 of 13
Mazis
753 Views, 12 Replies
Wall sections
Does anyone knows how can someone make in revit a wall section like the one that i attached in this topic?I can make only rectangular profiles of separated walls .
Thank you
12 REPLIES 12
Message 2 of 13
erik_snell
in reply to: Mazis
If you want a stand alone wall like the one in the PDF you can attach it to a sloped reference plane. You can also attach walls to slabs (floors) and roofs.
Autodesk Logo
Erik Snell, P.E.
Experience Design Architect
Autodesk Revit
I am an Autodesk employee and the opinions or commentary I provide are my own and not necessarily that of Autodesk, Inc.
Message 3 of 13
Mazis
in reply to: Mazis
As far as i know walls cannot be attched to vertical reference planes.The pdf file shows a wall section and not profile view.This is my problem.I haven;t found how can i attach a wall to a reference plane.
Message 4 of 13
erik_snell
in reply to: Mazis
Here is a section view. Made by attaching to a Ref Plane. If this is not what your looking for I've misunderstood. Please explain your wishes a little clearer.
Autodesk Logo
Erik Snell, P.E.
Autodesk Revit
Message 5 of 13
Mazis
in reply to: Mazis
I am sorry for not explaining correctly what i want. What i mean is that i want the section of the wall that is drawn in the pdf in Plan View.Not in section and not in profile view.
Message 6 of 13
erik_snell
in reply to: Mazis
Yeah after the last post I kind of figured. You are correct there is no way to side attach to a Ref Plane. Maybe someone else will have a good workaround.
Autodesk Logo
Erik Snell, P.E.
Autodesk Revit
Message 7 of 13
Joe.Charpentier
in reply to: Mazis
Have you tried cutting the end of the wall with a void?
(hopefully you don't have to do this in too many places.)
Joe
Message 8 of 13
Mazis
in reply to: Mazis
It seems like this is the solution but revit don;t cut the wall with a void. I create the void through a column where i delete everything and then create the shape and the void that i want.Does it matter that i make the void like this?And why i can;t cut the wall?It seems like revit wants a reference plane .
Message 9 of 13
Joe.Charpentier
in reply to: Mazis
Here we go, step by step:
1) Go to the plan view of the wall you want
2) on the modelling tab, select "create"
3) For the category, select "walls" (I don't know if this is required)
4) From the design bar select "Void Form>Void extrusion"
5) Sketch the slice you would like taken off your wall, constrain if necessary.
6) Finish sketch
7) Select the extrusion, give it the correct height/depth.
8) While still in the void creation tool, select "cut geometry"
9) Pick the void, then the wall.
10) Wall is now cut.
11) Finish family.
Joe
Message 10 of 13
Mazis
in reply to: Mazis
Thanks,Thanks,Thanks.And thank you....
Message 11 of 13
Joe.Charpentier
in reply to: Mazis
No Problem!
Joe
Message 12 of 13
aksha
in reply to: Mazis
1. Select your wall in elevation
2. In Type Selector, click on 'Edit Profile'
3. This takes you in sketch mode. Edit your sketch to suit your requirements.
4. In Design Bar, click on 'Finish sketch' and you are done.
Message 13 of 13
Joe.Charpentier
in reply to: Mazis
This method does work in elevation.
However, the original post was asking how to do this in a horizontal section through the wall.
See above posts for that answer.
Joe
