I'm new to revit. I'm trying to create a void (pocket) in my structural foundation (equipement pad). I created the foundation by using the model-in-place component tool. So I edit-in-place the structural foundation then construct the void form (I used Void Extrusion). When I'm finish I hit the OK button & I get this error (see image below).
Why?
How do you create void in structural foundation?
I ran it to this lately as well. Its actually cutting thru you analytical foundation not the actual foundation. You have to turn off the analytical foundation for it to work. Do that and you should be good to go.
Ex: Click on the foundation and up in the panel (ribbon) you will have a button that says disable analyitcal, click that and it will turn off the analytical founation, then place the void and join and it should work.
Once you create the void extrusion, you need to tell Revit manually, via the Cut Geometry tool, that the void cuts your solid. Revit will not automatically cut the solid. It will instead give you a warning message to remind you to use the cut geometry tool. Press Cut Geometry, Select the void, then select the solid. Finish Family...
