Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
View Range
2 REPLIES 2
jwheatley
467 Views, 2 Replies
View Range
I have linked CAD drawing that does not cut off at the view range established in m section views.  Any recommendations or has anyone else experienced this issue?  I can control the view by turning layers off but if I have a pipe run that beyonds the view range it shows the entire run.  Any help is greatly appreciated.
2 REPLIES 2
CoreyDaun
in reply to: jwheatley
I believe that you have to import the CAD file into a Family, and then load that Family into the Project to get it to obey the Section's View Range.
Chris.Aquino
The process as mentioned can be found here:
http://revitclinic.typepad.com/my_weblog/2011/04/importing-3d-geometry-from-autocad-mep-into-revit-m...
Chris Aquino
Adoption Marketing Manager | BIM Collaborate Pro
@Aquinotecture
