Hello to all.
I have a revit architecture file with the Terrain as a Toposurface. I imported as a revit link into revit structure, but I can`t visualize the terrain. (only the terrain: the toposurface).
The VG do not show the topography category and all the Model Category Visibility are check.
The Revit Link is by host.
In Reveal Hidden Elements the terrain appears pink, but I cant unhide by category or element.
also I check the template view of the View.
any help?
kind regards and thanks in advance
C
You should check site in VG and not topography. If you turn on Site, you should be able to see the topography. If you don't find site, make sure the checkbox below "show categories from all disciplines" is turned on. Hope this helps.
