Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Tilt Up Panel Joints
2 REPLIES 2
kiskander58
715 Views, 2 Replies
We show each panel as a separate wall segment with the joint size between segents. Does anyone know how to get the end of a panel to be 45 degrees? I know how do a miter if the walls are joined but once you disallow the join the walls square off. I've been mitering the walls and just drawing a bold detail line to show in plan but I'd rather do it right if possible. Any ideas?
2 REPLIES 2
wikerd
in reply to: kiskander58
Did you ever find an anwser to this ?
Ian_Bryant
not sure if it is what you are after,
but when you do your Miter, you can select "Don't Clean Join"
from the Display drop down on the Options Bar
& you get to see the Join Line.
Regards Ian
