Hi All,
Very new to Revit and am currently setting up our templates. My first question is can you edit, delete and add Parmeters to the Project Properties Table?
The out of the box parameters are ok but a little limited to what we what.
Thanks in advance.
I have had a read but the usual help files are rubbish!
Where do I go to modify what is listed within the Project Information Table?
Thamks
I understand all of that and have added the parameters I want.
What I'm after is if you go to Manage and open the Project Information Table, listed there are other parameters. I would like to modify and add to this. Where can you do this is it is at all possible?
Attched is the table I mean.
Cheers
Hi-
The parameters will only show up in the Project Information dialog if the category "Project Information" is applied to the parameter.
To do this, do the following:
-Add your new Parameter: (“Manage” Tab>Project Parameters, then in the Project Parameter Dialog Choose “Add”, or Modify an existing parameter.)
-In the Parameter Properties dialog, select the data type of the parameter you want to use, give it a name. Then, in the Categories list on the right hand side of the dialog, make sure "Project Information" is checked.
-Click OK in both dialogs to finish. Now if you go into the Project Information dialog, you will see your new parameter.
Joe
Yep, get all that and was being a little slow there!
But I'd still like to remove some parameters that are shown in the Project Information Table, but the ones I want don't appear in the Project Parameters Table where I can add or remove my own created ones?
Are these hidden types that are always there?
Thanks again.
Thanks Joe.
Getting there now!
Is there an easy way to create a parameter with a radio button like the Project Address parameter within the Project Information tab?
I have a long note that I wish to add to the sheet family that will change for each sheet, and doing it the same fasion as the Project Address for individual sheets seems a good way?
Joe,
The System Family: Sheets associtated with the Edit Label - Label Parameters / Category Parameters in the Title Block Family is uneditable?
My problem is we initially Labeled - Drawn By / Checked By etc... and now we want to remove from the Title Block. After deleting the labels from the family and reloading into the project, the option to modify these parameters is still showing in the Identiy Data when you select the Title Block. I have also run the Purge command on both the Title Block Family and the Project and it won't go away.
Also, there are are additional, non related items that have since shown up in the System Family: Sheets that i would like to delete. No idea how they got there.
Please help.
Jeff
Some things can not be deleted, because they are hard coded. For example if you start a new project without a template. If you then create a new sheet and for titleblock choose none you will end up with the following parameters
You can decide not to use them on the sheet, but they will always exist in the properties window of a sheet.
Louis
Please mention Revit version, especially when uploading Revit files.
Joe,
I take it there's no way to add parameters to the Project Information Table. I'm having the same issue TrevN has been asking about. I'd like to be able to add my consultants' websites to the list. I've created the parameters and assigned them to the Project Information group but they still don't show up in the table. I've tried adding the shared parameters to various families but I can't get the labels to populate--presumably because I can't add the info to these parameters.
Jeremy
Why is the Type-Button grayed out? Sometimes i want to have more Templates to choose from or a list with companies to choose from, so i dont Need to type the Company-Information in every time, but can just choose the Company Name.
