Hallo
I have to make a drawing of a suspension bridge. But is it possible to make that in Revit? Or are there an other program, there are better to that.?
Thank you very much for your help.
Sorry for my poor english
Søren
If you just need to 'draw' a suspension bridge, use AutoCAD. It's better and faster for 2D work. If you need to build a 3D model, I guess you could use Revit Structure for that. There may be a simpler, bridge specifc program - but I bet it's very expensive.
yes its possible with Revit, Revit and Civil 3D have good excange of land data.
you can use both to develope your Bridge.
try Revit extensions addins.
Hey,
I need to design a suspension bridge. Is there any program on autodesk where you can check for stiffness or cable strengths? Thank you very much!
Julian
Robot Structural Analysis may meet your needs.
You could head over to the discussion group there and ask:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/bd-p/351
Joe
