Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Sub-categories in families below other objects
1 REPLY 1
266 Views, 1 Reply
Hi
From the attached model you’ll notice the 4 pile pilecap. I’ve added symbolic circle lines to represent the piles. I’ve added them to a newly created sub-category (Piles Symbolic Lines) so I can give them a different linetype (the shorter dashed line.)
The problem occurs when it’s placed under a floor slab. The linework reverts to what is set in the Hidden Lines sub-category (the longer dashed line). Not sure if it’s the linework or the pile extrusion that’s showing.
So my question - Is there a way to get the piles to display with the shorter dashed linestyle when below the slab?
1 REPLY 1
So, I guess the answer is no. Smiley Sad
