Revit Structure
Valued Contributor
Message 1 of 3 (166 Views)
Structural Column Placement Visibility
166 Views, 2 Replies
03-05-2012 11:11 AM
I noticed that when I hit the column tool and go to start placing columns, the graphics of the column shape do not appear until I actually click.  However, if I think click on that column and hit "create similar" the column graphics do appear.  I also tried doing this and then changing the column type before placing, but the graphics disappear again.  Why is this happening?  We need to be able to see the column while placing it to verify the correct shape and orientation are being used.
Distinguished Contributor
Message 2 of 3 (128 Views)
Re: Structural Column Placement Visibility
03-15-2012 05:41 PM in reply to: kirbybeegles4894
Please let me know what version of RST you are using.
I was not able to reproduce the issue you are describing in 2012.
If this is not the issue please reply with an image, or the steps I could follow to reproduce it.
Have you checked on the graphic card? Maybe update the driver?
Valued Contributor
Message 3 of 3 (122 Views)
03-16-2012 07:24 AM in reply to: subpartner
Revit Structure 2012 - 64 Bit Windows 7.
I played with it a little more this morning, and I'm getting inconsistent results.  Sometimes the column at my mouse appears after I place one instance.  Usually, it will disappear if I change column types while still in the column tool.  Zooming in/out doesn't make a difference.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
