New the site, but here goes.. I am a steel detailer for over 25 years. I currently use 2D software that does a good job. However I do have some customers wanting KISS downloads which most 3D softwares produce (not 2D).. I have looked at SDS/2 software, Tekla software, Advance Steel software, and they all 3 do well it seems, but due to the high price, I am now looking at Revit Structures in conjunction with Autocad Steel Detailing.. I see good reviews about Revit, but not so good about Autocad Steel Detailing which seems to have many glitches.. I have read some say to do your model in Revit and then transfer it to ASD.. I also noticed that SDS/2 has an add-on to Revit now called SDS/2 Connect which gives you many more connections in Revit.. Are there any steel detailers out there that can clarify the "worthyness" of Revit with ASD or ASD in general by itself from the detailing standpoint? The price for the Autocad Design Suite Premium 2014 which includes both are well within reason price wise, but only if it works fairly well. As most detailers no, the end result for us is the 2D fabrication drawings in the end. The model to the customer really means nothing except a pretty 3D picture.. An evaluation by a steel detailer between Revit and ASD would be greatly appreciated... 2D fabrication drawings are the most important if the software will produce them with some resonable amount of work and not have to spend days doing clean up..
Thanks in advance for your time..
olecarman
I have used 2000iLT for years and 3 yrs ago transitioned to 3D modeling with ASD. In my opinion, ASD has a learning curve the size of a rainbow, After hours and hours of screaming at my monitors, I finally have been able to create shop drawings similiar to the ones you see in tutorials....(in between crashes and ASD crashes alot)............I am trying Advance Steel now, just started, but it can only be better than ASD........there just dosen't seem to be any training for any of them, everything I can find is just generic, surface scratching content.....Bear in mind as you read my comments, I have no formal training of any kind, just a lot of experience. Good Luck !
I haven't used ASD but have been using Autodesk products for around 8 years now, prior to that I used Tekla for around 10 years. There's a reason why Tekla is a lot of money and ASD/Revit isn't. If you can stretch to Tekla I'd go for it as it's simple superb for steelwork, I wouldn't touch Autodesk with a bargepole if I could help it!
I know that probably doesn't help, but them the facts.
Goof luck.
been using advance steel now for several months.....one word.......SWEET
