Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Stacked concrete walls
6 REPLIES 6
acaddog
209 Views, 6 Replies
In Revit 1008 Stacked Concrete Wall appear to be visible only ing in "coordination" discipline. Is this a Revit glitch?
6 REPLIES 6
in reply to: acaddog
Sure it's set to be bearing?
wrote in message news:5821131@discussion.autodesk.com...
acaddog
I do not see any way to set the "Structural usage" in the stacked wall properties.
Well now, isn't that odd. I don't remember having that problem in previous
releases.
wrote in message news:5821171@discussion.autodesk.com...
properties.
Okay, this is a pretty silly workaround, but if you change your wall to
something non-stacked, set the properties to bearing, then change it back to
a stacked wall, it will show up in structural views.
properties.
erik_snell
It does sound like the Structural Usage parameter. For Stacked Walls you will need to select the individual walls within the stack and set the parameter. You can select the individual walls by using your TAB key while pre-highlighting the stacked wall.
Autodesk Logo
Erik Snell, P.E.
Experience Design Architect
Autodesk Revit
I am an Autodesk employee and the opinions or commentary I provide are my own and not necessarily that of Autodesk, Inc.
acaddog
Hey! It's not nice, but it works.
Thanks all
Rail Community
