Show only
Search instead for
wrote in message news:5821131@discussion.autodesk.com...
In Revit 1008 Stacked Concrete Wall appear to be visible only ing in
"coordination" discipline. Is this a Revit glitch?
Okay, this is a pretty silly workaround, but if you change your wall to
something non-stacked, set the properties to bearing, then change it back to
a stacked wall, it will show up in structural views.
wrote in message news:5821171@discussion.autodesk.com...
I do not see any way to set the "Structural usage" in the stacked wall
properties.
It does sound like the Structural Usage parameter. For Stacked Walls you will need to select the individual walls within the stack and set the parameter. You can select the individual walls by using your TAB key while pre-highlighting the stacked wall.
Erik Snell, P.E. Experience Design Architect Autodesk Revit
I am an Autodesk employee and the opinions or commentary I provide are my own and not necessarily that of Autodesk, Inc.
