Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Slab edge doesn't host rebars
6 REPLIES 6
awes
3443 Views, 6 Replies
Hi! I'm not able to put rebars into slab edges based on library slab edge profile (RVT 2013 at least FIN GER SWE language packs). Any clues? There's no option to tick 'host rebar' profile family, profile type is slab edge and material is structural concrete.
6 REPLIES 6
fernanda.firman
in reply to: awes
I have no problem adding rebars into a slab edge.
Can you please describe how you are trying to place the rebars?
Can you add it in section view?
Fernanda Lima Firman
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
Revit Clinic
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
awes
in reply to: fernanda.firman
Dear Fernanda, my problem seems to be solved.
I'm now able to put rebars in slab edges based slab edges & profiles from structural project templates as well as slab edges based on profiles created by my own.
I'm not able to recreate the a slab edge that cannot host a rebar and yes I can now see the the structural property rebar cover. In the first hand I wasn't able to add rebars in any views using different options and my guess is that the original problem was related to a wrong chosen profile family template. I'm although sure that I used a profile with structural properties, profile usage slab edge and structural material as structural concrete.
I have an additional question related to profiles for structural use. Is there a family parameter for hosting rebars or is it a bonus that comes with  structural material or type of usage? Many thanks for your answer in advance.
AJA14
in reply to: awes
Hi. I'm not sure if this is your question, but any family that has the structural property enabled in the instance properties will be able to host rebars. So make sure you use a structural family to start a new one and enable structure to be able to host rebars.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
chrisplyler
in reply to: awes
I've found that if you create a new slab edge profile, using the Profile-Hosted.rft family, the family property "Profile Usage" will default to "<Generic>" and will not be able to host rebar. If you change that family property to "Slab Edge" then it will host rebar.
Of course you need to "Load Into Project", including all parameter values, after you've made this change, and also save the family so it will work the next time you use it.
xtn
in reply to: chrisplyler
LEGEND
You are amazing, thanks. that was the solution
