Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Sheet Pile Wall
4 REPLIES 4
alexbell7294
2306 Views, 4 Replies
Sheet Pile Wall
I'm mdelling a 180m sheet pile wall, which is straight in alignment, but step across three varying gradients spilt equally acroos the 180m. The piles are individual families (150+ No.). How can i change the level of each pile automatically to the varying gradients without doing this manually? Note: the pile need to be indvidual so they can be programmed? Void cuttng could be an option, but this is not possible in the project.
thanks
Alex
4 REPLIES 4
subhra_civil
in reply to: alexbell7294
Can you please send me your Revit File or send me some images on that particular place?
Thanks & regards,
Subhradeep Sen
Kolkata
India
alexbell7294
in reply to: subhra_civil
I've attched a print screen of the elevation and an 3D view, thanks
subhra_civil
Please send me your Revit File. The images is not clear to me. It is too far.
Thanks & regards,
Subhradeep Sen
Kolkata
India
thommynator
hi!
You can use adaptive family on a spline. Watch this tutorial:
http://revitstructureblog.wordpress.com/2013/12/06/revit-structure-2014-tutorial-modelling-piled-wal...
__________________________________________________________________________
www.EnjoyBIM.de | Revit, Dynamo, BIM and more | High quality training and Consulting in Stuttgart
Ihr fandet einen Beitrag hilfreich? Dann vergebt dafür doch Kudos!
Eure Frage wurde erfolgreich gelöst? Dann einfach auf den 'Als Lösung akzeptieren'-Button klicken!
