Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Service Pack 2 for Revit Products
5 REPLIES 5
ukdxb012
1637 Views, 5 Replies
Hi all,
I have been informed that SP2 has been released for all flavours of Revit, Structure, MEP and Architecture. However i need some help!!! When SP1 was released there was a cabinet / zip file provided with the update to basically update existing shared content that may be sat outside of the deployment. http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=16840966
Now that SP2 has been released there is a link to the actual installer but not content... Even though the readme's say that the update will effect content libraries. http://images.autodesk.com/adsk/files/autodesk_revit_structure_2012_update_2_readme.htm
Can anyone from Autodesk help as we want to deploy this asap. Basically, all i need is the cabinet / zip file made available. Updating the content any other way is a real pain as our content is not sat in our deployment images.
Duncan
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
5 REPLIES 5
ukdxb012
in reply to: ukdxb012
Is it simply a case that SP2 does not update the shared content but the instructions are still in the readme? Or are the references referring to SP1 because it is included in SP2?
I must say that this SP2 release is not very clear!
Duncan
Duncan Brannan
Twitter | LinkedIn
DarrenP
they release the updated content for update 2 now
DarrenP
ukdxb012
in reply to: DarrenP
Darren,
Thanks for pointing this out, really appreciate it! I see that Revit Architecture and Revit Structure have released *.zip files for content but not Revit MEP...
Duncan
Duncan Brannan
Twitter | LinkedIn
DarrenP
heres why for mep: Note: No additional content updates have been included in Revit MEP 2012 Update Release 2. Only the content updates provided in Revit MEP 2012 Update Release 1 are included in Revit MEP 2012 Update Release 2.
DarrenP
86.pravin
I have Export Revit Structure Sheet in DWG.
Below Problem Are Create
1) Hatch pattern are not clearly shown in AutoCAD File
2) Suppose my Revit Structure Layout Scale is 1:100 and this drawing I have send to dwg format then as per given scale
    Text Size are not Properly shown in dwg file
3) Exported revit Sheet in DWG file How control the line & shet TEXT. Border line colour
5) when I have draw the slab in revie structure beam mid portion the slab line are shown. I have erase this line using linework command but this is lanthy process. How I Work fast?
Pravin Sutar
Regard
Pravin
