I have a simple 24' by 24' concrete wall on top of a foundation. I'm trying to add a W8 x 24 (12' long) steel beam to each corner.
I can't seem to snap to the center of each corner. Revit wants to snap to the bottom of the wall at the foundation level.
I also can't select any beam besides the W26 that is loaded as default. I've gone to "Load family" and tried to load the structural steel folder (my size is in there) but I'm given an error message.
I'd also like to add a connection between the base of the column and the top of the walll, so that when I load this into Structural Robot I can do an analisys on strenght properties of the structure.
Can anyone point me in the right direction? I can upload info or provide any additional details. Thank You in advance.
