I have a problem with my custom Section head, and cannot figure out how.
If any one could help me out,
see the attached file and Image, I am using RST 2011
In the .rfa file, select the offending text and click edit type. Under the "Graphics" heading, on "Background" change this setting to "Opaque". That should work. I hope.
Thanks Brooks,
But the text is already opaque, it dint work that way.
The line still is projecting within the bubble 😞
Having re-read this, I feel like a moron... I thought you were talking about how the text is cutting into the lines of the section head. As for the line projecting into the head... it's a simple fix, I ran into the same thing. When editing the family, select all of it and move it to the left in the .rfa file. Sounds silly, but that's your problem. I with there was some indication in the .rfa file showing where the line would latch on to the head, but it doesn't. It's a guessing game, but still pretty simple to fix.
