Revit Structure
thuzz
Message 1 of 2 (130 Views)
Schedule/quantities by level
130 Views, 1 Replies
11-27-2012 06:33 AM
I wonder why the schedule parameter "level" doesnt exist in the list of available fields when I try to list the walls and columns in my project (two different schedules).
For all other objekts in the project (e.g. floors, windows and doors) I can choose "level" as a field and sort objects by level.
The walls are modeled as seperate objects for each floor.
Valued Contributor
kirbybeegles4894
Message 2 of 2 (126 Views)
Re: Schedule/quantities by level
11-27-2012 11:24 AM in reply to: thuzz
It probably has something to do with walls and columns having 2 level parameters: base level and top level.
It's a pain, but if you really need to seperate them out, phases or worksets usually works pretty well.  Alternatively, you could create a new parameter for all walls and columns called "Level for Scheduling" or something, but you would have to manually assign the values to all of the objects.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
