I have a column that I attached the top of to the Slab/Roof . I then added beams from the column tops out ward toward the wall. You can adjust the 05 and 04 jst. brg. Levels that host the front and rear of the Slab/Roof slope arrow. The grater the distance between the jst. Brg. Elev.s easier it is to see the error. Looking at the center col. line "D" W-Bm. coming at you the connection constraint to the top of the column is off the grid line "D". I am aware that the beams orientation may be changed to horizontal but that does not matter here. What am I doing wrong? Sorry so sloppy in a hurry will update wed.
