Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Revit Structure Composite Beam Design Extensions
3 REPLIES 3
jmmeagher
1411 Views, 3 Replies
When I try to use the Composite Beam design extension for Revit Structure 2012 I get the following error:  "1 of the selected members were not recognized types and will not be designed".  I have tried this with all of my members and I get the same error.  I am using a simple W shape beam and can't seem to get past this error.
3 REPLIES 3
jad.dellel
in reply to: jmmeagher
The withepaper and the movie below should help you, if not please send us you rvt file for deep analysis
http://www.ideateinc.com/whitepapers/bim/autodeskrobot_revitstructure_whitepaper.pdf
http://students.autodesk.com/ama/orig/structural_eng_2011/assets/videos/Ex_4-1_COMPOSITE-BEAM.mp4
Jad DELLEL
Sustainability Success Manager - Autodesk, Inc.
jmmeagher
Thanks.  I actually realized that there was an update to the Revit Extensions and once I downloaded the new update it seems to have taken care of the issue.
jad.dellel
Thanks for your feed-back
Jad DELLEL
