Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Revit Structure 2014 Add-ins & Extension
5 REPLIES 5
mpcloob
5735 Views, 5 Replies
 In the name of GOD .
hello to all...
 I am a student.
please introduce to me where is download links for download Add-ins & Extensions for Revit Structure 2014.
I 'm Await for your replies....:smileywink:
5 REPLIES 5
awes
in reply to: mpcloob
For the moment there are no download links for R2014 on students.autodesk.com as you probably have seen.
There are although several options for you to choose from;
- wait until the  R2014 extensions have been released for students
- buy an ordinary license and subscription for R2014 to get the appropriate links
- use previous versions to solve your tasks
Regards, Anders
cristoff_1
in reply to: awes
can the 2013 extensions work with 2014?
aris_atrox
I have the same question. Have you or has anyone tried the extensions of revit 2013 on 2014?
What I want to do is this,
http://wikihelp.autodesk.com/Revit/enu/2014/Help/0001-Revit_Us1/3130-Subscrip3130/3144-Globe_Li3144/...
or this,
have an add-ins tab (now I have one called extensions) that will lead me to a Global links panel and so on.
Would those extensions even help with my problem?
cristoff_1
 i left the extensions installed as they were installed separately from revit. I then uninstalled revit architecture 2013 and replaced it with 14. The extensions tab is still there in 2014 when i open it so i guess the 2013 extensions will wrk with revit 2014. Only thing is that you have to do the update to get the architectural template
engineer_civilman
m,nm,nm,j,nj,.mn
