Revit Structure
Active Member
mlynch
Message 1 of 1 (152 Views)
Revit Structure 2011 hangs on Splash Screen
152 Views, 0 Replies
04-27-2012 11:38 AM
Having a helluva time getting revit structure 2011 to run on a users machine. Structure 2012 runs fine. 2011 hangs at the splash screen and then a Windows error comes up saying the program has stopped responding. I've done all the usual tricks:
  1. Restart PC
  2. Uninstall/reinstall Revit
  3. Checked the WSommcntr2.exe process (its not running)
  4. Tried to delete WSCommcntrdata.xml, but it doesn't exist. Probably because 2011 has never started.
  5. Deleted UIState.dat
  6. Tried to launch from a different user profile
  7. Repair install of .NET framework 4
  8. Set registry for launching CommCenter to 0
I'm still getting the same error. I will attach the Application Log, the actual Windows error codes and the Revit Journal from the latest attempt to launch it. I'm at a standstill. Any help would be greatly appreciated
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
