Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Revit License Unavailable, unable to obtain a floating license
3 REPLIES 3
LisaDrago
1310 Views, 3 Replies
Hello - I am having some issues and was wondering if anyone could give me a hand... this is what is coming up.
Revit License Unavailable, unable to obtain a floating license, if outage persists contact the license administrator, no connection to license server could be established.
How can I fix this?
Thank you for your help.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
3 REPLIES 3
autodesk
in reply to: LisaDrago
Did you find a resolution to this problem? We are having a similar issue. Let me know if you came to some conclusion.
Thanks.
Kenneth Brown
LisaDrago
The problem ended up being that the license manager was not running, so they were unable to find the license.
Hope this helps..
Lisa
holly
what did you do to make the license manager run again?
SBeng
AutoCAD LT 2012
Windows 7 - 64 bit
