I have the revision schedule showing up on my title block as I want it apart from the actual revision number/ref.
We get a standard option of leters A, B, C etc or 1, 2, 3 or nothing.
Is there a way to have an automated reference that can go P1, P2, P3, C1 etc as per the attached file?
Solved by AJA14. Go to Solution.
Well that is quite simply a load of rubbish and should be changed as soon as possible, Autodesk, are you listening?!!!!!
