Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Revision Numbering Option
2 REPLIES 2
TrevN
425 Views, 2 Replies
I have the revision schedule showing up on my title block as I want it apart from the actual revision number/ref.
We get a standard option of leters A, B, C etc or 1, 2, 3 or nothing.
Is there a way to have an automated reference that can go P1, P2, P3, C1 etc as per the attached file?
2 REPLIES 2
AJA14
in reply to: TrevN
These are hard coded in Revit and cannot be changed. It's either numbers or letters. All you can do is manipulate the order or existence of letters. (Some people don't like the O and I).
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
TrevN
in reply to: AJA14
Well that is quite simply a load of rubbish and should be changed as soon as possible, Autodesk, are you listening?!!!!!
