Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Reinforcing in Revit 2014
3 REPLIES 3
cceleeds
675 Views, 3 Replies
Morning
Please could someone help me.
I am reinforcing a concrete beam in Revit 2014, when i add links (shape code 51) it shows the links correct in the 3D view but in the section view only half of the link is showing and on plan none of the links (shape code 51) are showing unless i make the beam transparent. I have attached the section and 3D view.
When i detail a column, the links show correct on plan, section and in 3D.
Is this a bug or is it a setting i have missed? Thanks in advance.
Ian
3 REPLIES 3
erik_snell
in reply to: cceleeds
In the rebar properties check the visibility property so that the rebar is viewed unobscured in both the section and the floor plan.
Autodesk Logo
Erik Snell, P.E.
Experience Design Architect
Autodesk Revit
I am an Autodesk employee and the opinions or commentary I provide are my own and not necessarily that of Autodesk, Inc.
cceleeds
in reply to: erik_snell
Erik
This sorts out the plan, but it is still not showing correct in section.
Ian
erik_snell
Have you looked at where your section is taken? Does it actually cut the rebar set with the cut plane? Also what is your level of detail for the section?
Erik
Autodesk Logo
Erik Snell, P.E.
Autodesk Revit
Rail Community
