Revit Structure
New Member
Message 1 of 4 (809 Views)
Reinforcement schedule
809 Views, 3 Replies
03-13-2012 03:11 AM
Hello!
I have trouble with rebar schedule.
I am trying to make an automatical rebar schedule that will be sent to rebar factory, and will be used to bend required rebars. I guess there is no way to add rebar shape sketch to schedule. At moment i made schedule with rebar part lengths A, B, C, D, .. and it is hard to understand what is the rebar shape and which dimension corresponds to which rebar part. Furthemore i have Z shapes and C shapes, and they both have length values in A, B and C fields, so factory workers won't know how to bend them, in C or Z shape. I know that i can draw sketch manualy, but i want everything to work automaticaly, if i add new rebars, i want them to apear in schedule and i won't need to make any other changes than in 3d model.
Maybe there is a way to make everything work smooth? Maybe i missed something, and there is a way to make easy readable rebar schedule?
Thank you!
engr_mondo
Message 2 of 4 (791 Views)
Re: Reinforcement schedule
03-13-2012 05:55 PM in reply to: vvvitalikkk
Please clarify if the values of A, B, C...and G are automatic in your schedule also or hard coded.
Mondo
New Member
Message 3 of 4 (783 Views)
03-14-2012 01:04 AM in reply to: engr_mondo
The values A, B, C .... are automatic, they depends on shape of rebar. But, as i told, it is impossible to understand what shape it is, if we consider only values of A, B, C, ... G.
Valued Contributor
Message 4 of 4 (773 Views)
03-14-2012 04:13 PM in reply to: vvvitalikkk
Can't you just add a drafting view that shows the shape and put a big letter "A" or whatever underneath?  I've seen lots of rebar shops done this way and it doesn't seem to be too much of an issue.  You can also label each dimension leg on your sketch so even if you have 2 different shapes with the same dimension, it will be clear which it is.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
