Hello
I have a question and i hope to find an answer here
the letters 'a, b, c, c1,c2, d, d1, d2, e, e1, e2, f, f1, f2,...in the properties of rebar
my question is the schema of these parameters to understand which part can modified
please if someone can share a shema of these things.
Solved by jad.dellel. Go to Solution.
It depends on the type of the Rebar, but you could find the definition by following these easy steps:
1- Select your Rebar,
2- Edit Family
thank you for your answer but i want to see like this foto to understand
I recorded all steps in this movie:
http://screencast.com/t/0QVUxzy6Bt
I hope this will be clear enough.
regards,
