I need to place rebar in my model of bridge from bridge modeler extension, and i can't rebar the slab and deck because is a mass elements. How i can do?
If you are selecting the element and the "Place Rebar/Reinforcement" button is visible on the Contextual tab, then you first need to be in a view where you can place rebar (a view that cuts the element you want to reinforce).
If there is no "Rebar" button on the contextual tab, you must edit the family. In the Mass family, there is a parameter for "Can Host Rebar" in the family properties. Make sure that is checked.
Joe
