Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
REVIT ORIGIN
1 REPLY 1
AJA14
360 Views, 1 Reply
REVIT ORIGIN
Hi. I created a template and used it to create a project but have added so many during the project and want to save this project as a template. I have already made a save as, detached from central, and deleted the project leaving the layers and families and drafting views and title block as part of the template. But now I want to return the base point to the 0,0 because I moved it during the project. The problem is I can't find it. I am using shared coordinates.
How do I locate the origin in this case and is it enough to just change the coordinates back to 0,0.
Should the project coordinates be the origin.
I would appreciate any ideas.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
1 REPLY 1
CoreyDaun
in reply to: AJA14
If you activate "Reveal Hidden Elements", you will be able to see the symbols illustrated below (which are overlapping in a normal project):
You can find additional information in WikiHelp: Shared coordinates, Project base point and Survey point
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
