Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
REVIT 2014 & REVIT 2014 LT - RHS, SHS etc Columns
1 REPLY 1
523 Views, 1 Reply
We are now using 2014 and 2014 LT on some of our projects and intend to use these packages for any new projects rather than 2013 as previously. However both of the 2014 packages seem not to be showing the hidden lines (thicknes of wall) for RHS or SHS members used as columns depending on the orientation of the column. ie  visible in one direction but not at 90 degrees.
Have just noticed this is also true of CHS members used as columns or framing!
Any pointers to what I have done wrong or am missing would be appreciated.
1 REPLY 1
Joe.Charpentier
The "hidden lines" in these families are usually detail lines that are only visible from certain orientations.
You could add  the additional lines to the family if they are not appearing.
Could you tell me the exact names of the families that are affected?
Joe
