Hello!
Recently I have downloaded Revit 2013 and Robot 2013 (both with student license) in order to get some knowledge about cooperation of those software. And I have met strange problem at a very beginning. I tried to find out what's the Reinforcement Code Check function (don't know the exact name as I use my native language pack) - so I modeled simple concrete column (using famili given) and I wanted to export it this way to add reinforcement. All was going pretty well - I was asked about specification to choose and so on. But when Robot was trying to import the column error occured:
Reinforcement export exception!
REX:
Engine version: 2013; Version name: ; Culture info: pl-PL
PLATFORM:
Win32NT Microsoft Windows NT 6.1.7601 Service Pack 1
SOURCE:
AREX
And there was a long log with info like this:
MESSAGE: (2012-12-15 15:37:53)
(...) StackTrace: w REX.DReinfColumn.ReinfFactoryRevit.ExportToRobot(RobotImport import, RnfColParam RectColPar, RCAD_DB_Bar[] dbParm, RnfColReinforcement Colrebar, RnfColSteelElemParam SteelPar, Extension ext, Boolean IsReinfObject, Boolean _IsFreezed, Boolean _TransferGeometry, Boolean _TransferReinforcement, REXMaterialConcrete _ConcretePar, AREXRnfColMngr RnfMan)
w REX.DReinfColumn.ReinfFactoryRevit.OnRun()
DEPENDENCY: Autodesk.REX.Framework, Version=2013.0.0.0, Culture=neutral, PublicKeyToken=51e16e3b26b42eda (file version: 2013.0.0.2251) | REX.Controls, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (file version: 2013.0.0.2251) | REX.Controls.WPF, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (file version: 2013.0.0.2251) | REX.Controls.Forms, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (file version: 2013.0.0.2251) | REX.Mathematics, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (file version: 2013.0.0.2251) | REX.Preferences, Version=2013.0.0.2251, Culture=neutral, PublicKeyToken=null (file version: 2013.0.0.2251) | REX.System, Version=2013.0.0.2251, Culture=neutral, PublicKeyToken=null (file version: 2013.0.0.2251) | REX.Service, Version=2013.0.0.2251, Culture=neutral, PublicKeyToken=null (file version: 2013.0.0.2251)
I have copied only english parts of the log. It mainly says that program could not load a dll library while trying to develope QueryInterface for model member COM in order to get interface with ID '{CEE36FA0-885D-11D2-AF83-0080C86BDF8D}'.
I have no idea what it all means but as far as I know it doesn't work with beams either.
Could anyone help me with this issue?
Piotr,
Podeslij mi plik Revita z slupem ktory chcesz przeslac do Robota. Jak jest wiecej slupow w modelu to zaznacz (np. na zrzucie ekranu) ktory to slup. Dodatkowo przeslij zrzut z parametrow ktore ustawiasz przy eksporcie.
Na przyszlosc - mysle ze lepiej bedzie jak pytania dotyczace linku z Robotem bedziesz wpisywal na forum Robota.
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/bd-p/351
Witam,
Dzięki za zainteresowanie problemem. Następnym razem będę pisał na forum Robota, aczkolwiek tym razem kierowałem się tym, że funkcja z której korzystam znajduje się bezpośrednio w Revicie (nawet jeśli jest to odnośnik do Robota).
Wracając do problemu: otworzyłem przykładowy projekt konstrukcyjny i tam po zaznaczeniu dowolnego słupa używam funkcji Analiza -> Analiza i wymiarowanie -> Projektowanie zbrojenia. Program zaczyna się łączyć z Robotem. Pojawia się okno dialogowe z wyborem normy do przeliczania zbrojenia i bazą prętów zbrojeniowych (ustawiam eurokod, a bazę prętów pozostawiam polską). Następnie rozpoczyna się "Przesyłanie elementu Słup (nr słupa)" i w tym właśnie momencie wyskakuje błąd. Analogicznie dzieje się, kiedy próbuję ładować jakiekolwiek belki.
Ten sam błąd wyskakuje niezależnie od plika na którym pracuję tj. nie ma róznicy czy jest to mój plik, przykładowy plik revita czy jakiś plik od znajomych, którym ta funkcja działa.
Chciałem przesłać jakiś swój plik .rvt, ale przekraczają maksymalny rozmiar załącznika. Dlatego dorzucam jedynie raport z błędu.
Pozdrawiam
Zrobilem pare testow i w moim przypadku opcja dziala poprawnie. Jaki jest rozmiar pliku rvt po jego spakowaniu?
Około 4.2 MB.
Właśnie tego nie rozumiem. Robiłem dziś identyczneoperacje na innym komputerze i tam nie było problemów.
Od razu dodam, że robiłem reinstalacje obu programów jak i zmieniłem Microsoft NET.framework na wersję 4.0 (plus aktualizacje), ponieważ słyszałem, że z 4.5 są problemy. Nie pomogło.
Przyznam, że nie jestem na tyle zaawansowany komputerowo, żeby zrozumieć o co chodzi. Proszę o nieco bardziej szczegółowe wyjaśnienie 🙂
Nie ogarniam tego do końca. Ten link wydaje się być przeznaczony dla win XP.
Znalazłem ten, dla win 7:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9583842&linkID=9243099
Ale po wpisaniu "bcdedit" żadna komenda więcej nie działa.
Nie wiem jak inaczej się za to zabrać. Czy w ogóle problem z pamięcią na systemie 64 z 8GB RAM może wystąpić?
Dodatkowo załączam plik journa, gdyby miał się przydać.
Na 64-bit systemie nie, ale w pierwszym poscie jest podana informacja o innym:
PLATFORM:
Win32NT Microsoft Windows NT 6.1.7601 Service Pack 1.
Sprawdz prosze skrzynke pocztowa. Wyslalem Ci maila z prosba o dodatkowe informacje.
Jaka norme i baze pretow ustawiles w parametrach linku?
Nie ma zadnego problemu. Zobacz prosze czy jestes w stanie prawidlowo przeslac slup do modulu wymiarowania za pomoca eksportu slupa do modelu Robota wedlug krokow pokazanych na zalaczonym obrazku.
W ten sposób wszystko wydaje się działać. Nie ma komunikatów o błedach, słup ma identyczne wymiary.
W tamtej funkcji zaraz po błędzie pokazywał się jakiś słup w Robocie, ale miał zupełnie inne wymiary, np. był 0.4x0.4 (w Revicie jest 0,3x0,3), wysokość zmieniona na 2,69 oraz zupełnie inne wymiary belki i płyty.
Mam wrazenie ze przy instalacji nie wszystkie pliki zostaly poprawnie zainstalowane w systemie. Mozesz sprobowac przeinstalowac Robota i Revita (zakladam ze nie masz zainstalowanych Revit Extensions, ktore sa dostepne tylko dla uzytkownikow z wazna subskrypcja), albo uzyc tego drugiego sposobu przesylania danych do Robota.
Niestety, nie pomaga. To była pierwsza moja myśl i próbowałem reinstalacji już dwa razy. No nic, ważne, że mogę jakoś ten błąd obejść. Dzięki za zaangażowanie.
