Revit Structure
Valued Mentor
AJA14
Message 1 of 10 (437 Views)
Problem with revit extensions
437 Views, 9 Replies
02-16-2013 04:22 AM
Hi. This is what happened when trying to add reinforcement for columns using the extensions. Any ideas.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
Product Support
Artur.Kosakowski
Message 2 of 10 (389 Views)
Re: Problem with revit extensions
02-20-2013 01:28 AM in reply to: AJA14
My assumption is that you still work with the original 2013 version of REX. Please try to download  and install its newer version (2013Q3) where this issue should be corrected. The newer version replaced the older one on Subscription site.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Valued Mentor
AJA14
Message 3 of 10 (357 Views)
02-20-2013 05:51 AM in reply to: AJA14
Hi Artur. I downloaded the updated extensions but still facing the same problem. I don't have this problem with other projects so I don't think it is only related to the extensions.
This is a 30 floor tower with a central file and 5 locals and about 8 worksets. Do you think that this could be the cause of the problem.
Ali Al-Hammoud
Product Support
Artur.Kosakowski
Message 4 of 10 (351 Views)
02-20-2013 06:00 AM in reply to: AJA14
I can't tell without having a chance to check. Could you try to isolate the column where this happens and save it in a 'new' Revit file. If you still have the same situation attach this file.
Artur Kosakowski
Valued Mentor
AJA14
Message 5 of 10 (326 Views)
02-21-2013 05:21 AM in reply to: Artur.Kosakowski
Hi. Artur. Take a look at the attached file. If you notice that the revit extensions will not work eventhough all I have is one column and a sheet.
However, what's weird is that if I delete sheet from the project browser and then use the extensions, it works.
Regards.
Ali Al-Hammoud
Product Support
Artur.Kosakowski
Message 6 of 10 (312 Views)
02-21-2013 06:28 AM in reply to: AJA14
I can't see such problem.
Artur Kosakowski
Valued Mentor
AJA14
Message 7 of 10 (304 Views)
02-21-2013 07:23 AM in reply to: Artur.Kosakowski
That's really strange. Like I said, when I delete all my sheets, it works fine. Anyways I'll let you know what I find out.
Ali Al-Hammoud
Product Support
Artur.Kosakowski
Message 8 of 10 (298 Views)
02-21-2013 08:04 AM in reply to: AJA14
Please check which version of REX you have installed as shown on the attached picture.
Artur Kosakowski
Valued Mentor
AJA14
Message 9 of 10 (273 Views)
02-23-2013 09:35 PM in reply to: Artur.Kosakowski
Hi Artur. I have a different version. See attached image. Although I did install the latest from the autodesk website. Could you please provide a link to the correct version. I would really appreciate that.
Regards.
Ali Al-Hammoud
Product Support
Artur.Kosakowski
Message 10 of 10 (254 Views)
02-25-2013 12:45 AM in reply to: AJA14
It is available from the Subscription site (see the attached picture).
Artur Kosakowski
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
