I´m having troubles setting up the families in Revit to use the SDS2Connect plug-in. After initializing SDS2Connect, it doesn't recognized the family's types. When I checked the project the following warning appeared: error: Element family requires set up. I don't know how to set up the family I've tried lots of things. I have also seen another warning that says the material is not found or something like that. If someone knows how to solve this problem please help me. I need to model these steel connection for my undergraduate project at the university.
Thanks a lot,
Diego
You can write to: valencia-diego@javeriana.edu.co or diego_fernando_valencia_rivera@hotmail.com
