Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Precast columns
3 REPLIES 3
666 Views, 3 Replies
Precast columns
So i m makings drawings for precast columns, we did this before with autocad, and a lot of homemade lisp that make work efficent,
i m familiar with the architecture side of revit but never did structure. i now have followed 5 days lessons in structure, but i m not sure how to draw those precast,
the conditions are:
they have to be for the fabric who made them
the have to have the same layout
i need volume, mass, column name, type column, every piece inside the column,
i m that far i made a viewtemplate for the front/left, etc...
i made the half of a sheet, but i m stuck on that.
anyone knows some fast work arounds cause how i now see it, autocad goes a lot faster.
3 REPLIES 3
You go to the column option. Select column>go to properties>edit type>load precast column. You will get different types of column type not only precast. After that place that type of column in the floor plan. After place a column you can change the column name, column type also by duplicate naming. You can also give the column material as per your requirement.
For extract column volume you have to go to Schedule/Quantity option.
I dont understand what do you mean by "every piece inside the column". Please clear it.
Subhradeep Sen
India
Kolkata
well now you"re talking about the architecture side of the columns, to transport it you need ancras, if some bars goes from one column to a upper column you need to put couplers in. etc... the meaning was to set this in a assembly, and then take the views from that element and his pieces in one view and put some labels and annotations on it. i know how to draw in revit, but i m not sure if i m using the correct methode for getting the full output
Joe.Charpentier
The Assemblies functionality is probably the best think for you in this use case.  You can add the columns, as well as any reinforcing, embeds, connectors, corbels (if you want to model them seperately) as
If you are a programmer (or have one in your company) creating an API plug-in to automate some of the drawing creation could be helpful for you.  There is a separate  API discussion group, located here if you have questions:
http://forums.autodesk.com/t5/Revit-API/bd-p/160
Joe
