So i m makings drawings for precast columns, we did this before with autocad, and a lot of homemade lisp that make work efficent,
i m familiar with the architecture side of revit but never did structure. i now have followed 5 days lessons in structure, but i m not sure how to draw those precast,
the conditions are:
they have to be for the fabric who made them
the have to have the same layout
i need volume, mass, column name, type column, every piece inside the column,
i m that far i made a viewtemplate for the front/left, etc...
i made the half of a sheet, but i m stuck on that.
anyone knows some fast work arounds cause how i now see it, autocad goes a lot faster.
You go to the column option. Select column>go to properties>edit type>load precast column. You will get different types of column type not only precast. After that place that type of column in the floor plan. After place a column you can change the column name, column type also by duplicate naming. You can also give the column material as per your requirement.
For extract column volume you have to go to Schedule/Quantity option.
I dont understand what do you mean by "every piece inside the column". Please clear it.
Subhradeep Sen
India
Kolkata
The Assemblies functionality is probably the best think for you in this use case. You can add the columns, as well as any reinforcing, embeds, connectors, corbels (if you want to model them seperately) as
If you are a programmer (or have one in your company) creating an API plug-in to automate some of the drawing creation could be helpful for you. There is a separate API discussion group, located here if you have questions:
http://forums.autodesk.com/t5/Revit-API/bd-p/160
Joe
