Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Places List Not Going to Correct Folder
1 REPLY 1
kirbybeegles4894
322 Views, 1 Reply
I've set the locations for the Imperial Library and Imperial Detail LIbrary folder to a location on our server, but whenever I go to place a detail component and hit load to load a new family, it takes me to the location for the Imperial Library, not the Imperial Detail LIbrary.  Any idea what might be causing this to happen?
1 REPLY 1
Thank you for your post.  In this case one thing to test and execute is the manipulation within the “places” list to navigate to the desired location.  To do this you will first navigate to the options dialog box, then to “file locations”.  Once you are here you will then click on “places”.  This will show you the content library locations loaded up.  What you can then do once you have added your network location, is use the arrow symbol to the left and move it to the top of the list to be the first selected when loading families.  Please test this and let us know how this worked out in your configuration.  Thank you.
DataLibraryLocations
Defines the locations of Revit data libraries.
Type = string
Example:
DataLibraryLocations=Imperial Library=C:\ProgramData\Autodesk\RVT 2013\Libraries\US Imperial\,Imperial Detail Library=C:\ProgramData\Autodesk\RVT 2013\Libraries\US Imperial\Detail Items
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
