Revit Structure
Active Contributor
PAULRYMAL7709
Message 1 of 3 (482 Views)
Pile Caps Reversing to bottom of Pile
482 Views, 2 Replies
03-28-2013 09:30 AM
Back again here. Thanks again for the replies. I have tried to find some info on placing piles under a grade beam, but as usual can't find nothing on it for revit. Everything shows Piles from the Level 1 and up. Whats happening is my pile caps are going to the bottom of the pile. I can't figure out how to do this without giving the pile a negative offset. I finally made a new Elevation called "Base Pile" set @ -30' from the underside of my grade beam. Still won't go. I am attaching 3 screen shots to show what I am doing & perhaps someone can point me in the right direction!
Paul
Distinguished Contributor
awes
Message 2 of 3 (470 Views)
Re: Pile Caps Reversing to bottom of Pile
03-28-2013 09:47 AM in reply to: PAULRYMAL7709
Hi Paul, please use an ordinary RC-beam as pile cap. Attach your pile to the bottom of your beam by clicking your pile and using /Modify Columb/Attach Top/Base + Offset from Attachment to find the right top level. Anders
Active Contributor
PAULRYMAL7709
Message 3 of 3 (460 Views)
03-28-2013 11:40 AM in reply to: awes
Worked like a charm! Thanks so much for the help & quick response. Really appreciated! Paul
Edited by
Discussion_Admin
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
