No. Revit can print any paper size. It is your printer driver that must have
the paper size listed. It is a Windows thing. If it isn't there - check the
printer diver setting in control panel. The HP's don't list all sizes by
default. You need to manually enable them. If your driver doesn't have a
certain size, you can always use custom.
wrote in message news:5823467@discussion.autodesk.com...
We are having problems with paper sizes that are showing in our printer
properties not being available in Printer Setup Paper Sizes. Does Revit only
have certain paper sizes hard coded in, and any others you want just have to
be created as custom paper sizes?
