Subcategories are used for user defined objects in non-system family
families. such as doors, casework, columns, etc.
Flush the "plan rep" from your brain. That was ADT. This is Revit. What you
are looking for is view settings and view templates. Each view can have its
own line setup for each object type. It is far simpler than trying to
configure everything at the object level as in ADT. This is all very basic
Revit stuff.
wrote in message news:5793127@discussion.autodesk.com...
What does the subcatagories in the Object Style Settings box control? I
know you can create new ones and modify existing ones, but I don't see any
changes to the objects when these are changed. For example, there is a
"Plan Rep" subcatagory under the "Structural Foundation" catagory. I made
some changes in this subcatagory so they were different than the main
catagory and didn't see any difference. It seems that it only reads the
settings that are set on the main catagory. The reason I'm asking
specifically about the "Plan Rep" subcatagory is that I would like to see
different colors and linetypes on my plan views than what I see in my 3D
model views. For example, we show a dashed line for wall footings on our
plans. But, I would like to see a solid line for the 3D model view. Is
this possible?
