Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Object Style Subcatagories
3 REPLIES 3
380 Views, 3 Replies
What does the subcatagories in the Object Style Settings box control? I know you can create new ones and modify existing ones, but I don't see any changes to the objects when these are changed. For example, there is a "Plan Rep" subcatagory under the "Structural Foundation" catagory. I made some changes in this subcatagory so they were different than the main catagory and didn't see any difference. It seems that it only reads the settings that are set on the main catagory. The reason I'm asking specifically about the "Plan Rep" subcatagory is that I would like to see different colors and linetypes on my plan views than what I see in my 3D model views. For example, we show a dashed line for wall footings on our plans. But, I would like to see a solid line for the 3D model view. Is this possible?
3 REPLIES 3
Subcategories are used for user defined objects in non-system family
families. such as doors, casework, columns, etc.
Flush the "plan rep" from your brain. That was ADT. This is Revit. What you
are looking for is view settings and view templates. Each view can have its
own line setup for each object type. It is far simpler than trying to
configure everything at the object level as in ADT. This is all very basic
Revit stuff.
wrote in message news:5793127@discussion.autodesk.com...
this possible?
you may want to look at using filters for this.
Brian Earsley
www.arete3.com
18645 West Creek Drive
Tinley Park, Il 60477
708.342.1250 x.225
this possible?
Thanks guys, I think the View Template is what I was looking for. Thanks for your help!
