Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
OLE object into Revit.
3 REPLIES 3
andrea_pontiggia
5196 Views, 3 Replies
Hi, I wanted to know if it is possible to insert an OLE object into Revit. thanks
Andrea
3 REPLIES 3
At this time, it is not possible to insert OLE objects directly into Revit. If you need to insert a Word or Excel document, you can insert it into a .dwg, then link that dwg.
We understand that this may not be the preferred workflow, but this issue is already logged with our Development group.
Chris Aquino
Adoption Marketing Manager | BIM Collaborate Pro
@Aquinotecture
afg01
in reply to: andrea_pontiggia
I tried linking an AutoCAD file containing an Excel sheet.  Revit strips the OLE object every time.  Is there a setting that I'm missing?
jasonmccool8686
in reply to: afg01
Yeah, being able to insert pdf's would be really handy too. The other issue with linking in a document through ACAD is that Revit wants to reformat the text in a linked (not inserted) autocad drawing. That just completely baffled us that Revit would reformat text in a general notes sheet that was linked.
