Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Moving model components and having detail views update
1 REPLY 1
jimk
495 Views, 1 Reply
We have a situation where we have a 16 story or so model drawn. The client has come back and stated they would like to add another floor. So our Structural guy was going to move the roof, penthouse, etc. up 14' so he could stick in another floor. We have tried a couple of different ways to move it, each time it wants to blow out all of the detail views. Several details have been derived from this model, with several annotative detail components added. What I mean by that, is the detail is a hybrid, some model, some 2d annotation.
Without getting to wordy - any way we can accomplish moving the top two floors (Roof area and Penthouse) up 14' without blowing away have of our details?
It looks like we can move the levels up 14' - then come back and stretch the detail callouts up - then go to the view and move the annotation up 14'. There are a lot of details, so it becomes tedious.
Wondering if there is a better way?
1 REPLY 1
fernanda.firman
in reply to: jimk
Unfortunately there is no easy way to achieve that. You can use tag (instead of just text annotations) and they will move with the element that it is attached to.
If you are using filled region, you can lock the lines to the model elements and they will also move.
But the drafting lines and text will stay in place with the view and you will have to move them manually.
Fernanda Lima Firman
Technical Support Specialist
Customer Service & Support
Revit Clinic
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
Rail Community
