Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Locking project browser & properties dialog boxes
2 REPLIES 2
aradinie
441 Views, 2 Replies
Dear sir...
am a new user in Autodesk Revit structure 2013 , when i open the program and start to creat levels , the Elevations (Building elevation) is invisible the project browser , so i can not creat the levels, please see attached fileRevit stuc.2013.png
2 REPLIES 2
AJA14
in reply to: aradinie
Hi.
1- You are on a plan view (level 1) so you will not be able to see any elevations.
2- The screen shows the modify wall contextual ribbon, which means that you have selected a wall.
3- To create levels, you need to be in an elevation view, and then you can create levels from the home ribbon or by copying the existing level and changing to a plan view.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
Joe.Charpentier
It appears that you are not using any template.
I would reccomend starting from a template.  If one of the supplied templates is not what you need, modify it and save a new version for  use in the future.
Joe
