Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Loading in Revit Structure
1 REPLY 1
GHASEM_ARIYANI
281 Views, 1 Reply
Hi
Can you explain to me  Loading and analysis  What is the Revit Structure?
Whether you are the analysis?
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
1 REPLY 1
In general, analysis is not performed within Revit Structure.
You need an external program or an analysis add-in to run an analysis on the Revit Structure Structural Model.
Robot Structural Analysis, Etabs, RISA analysis software packages (and more) all have links to Revit Structure.
Joe
Rail Community
