I'm trying to link an AutoCAD file containing polylines with a width thickness and with broken linetypes.
Although the colour is retained, all other linework properties appear to be lost. Please can someone advise the correct procedure to maintain linetype scale in Revit, and is there a way to maintain a polyline width setting?
Alex
Solved by conormccartney3897. Go to Solution.
Solved by CoreyDaun. Go to Solution.
I would say place the Polylines of similar width/Linetypes on their own AutoCAD Layer so you can assign a Thickness and Line Pattern to that specific Layer under Object Styles » Imported Objects tab.
The timing of this question is probably the answer, but is there any plans to fix this bug?
I got around this by creating a dynamic block with a "polyline" on defpoints to create a border at the correct width and filled it with a solid hatch. In my case it allowed me to have rebar that had the correct width.
