Ok so I am working on our structural model and I linked the Architectual model in. What I am trying to due is cut smy structural section over the arch section which is halftoned out. I go through visibility graphics and turn off what I do not want to see on the linked arch. model etc. etc...Everthing seems to be working great then............There is something I cannot turn off. It is a region, does anyone know how to turn the linked regions off? I'm I going around the right way of doing this?
I am assuming that since you can see the region that belongs to a Linked Model, then your V/G Overrides » Revit Links » [Arch Link] » Display Settings are set to "By Linked View". In order to be able to turn off that filled region, you will have to change the setting to "Custom", switch to the "Model Categories" tab, set the "Model Categories:" drop-down to "<Custom>", and then turn off the Detail Items Category.
You have limited options, since there is no specific control for Filled Regions. You can turn off the Surface Pattern visibility for the Detail Items Category to hide the hatch pattern, but that will affect all Detail Item elements. Also, the boundary lines will still display unless those lines (whatever Subcategory) are turned off.
I guess you could also place your own Masking Region over the Filled Region too, if that is of any help. But that would mask any Model Elements beneath, as well.
