Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Linked Revit Model
3 REPLIES 3
kellyroper2349
496 Views, 3 Replies
Linked Revit Model
I have linked in a Revit model from our Architect for a project. I am trying to turn off the visibility of several arch. elements such as door, windows, casework, cabinets, counters, etc. When I go into the visibility graphics dialog and go to the linked categories I have no options. I can only turn off and on the model, not the elements in the model. Does anybody know what is happening?
Also, they have established worksets in their model. Is there anyway to utilize these to my benefit? When I turn the visibility of these worksets off nothing happens.
3 REPLIES 3
in reply to: kellyroper2349
Pls . try :
View - temporary hide/isolated-hide element.
In the Visibility Graphics dialog, under Revit links, click on "by host
view" for the link you want to change. Then instead of "by host view",
select "custom". Now you can turn off whatever you want.
wrote in message news:5771157@discussion.autodesk.com...
is happening?
You need to set a specific view in the linked model to be active, via the Custom visual graphics settings for the linked model. You'll also have to have some idea what the Architect put on each of these worksets.
P.S. Workset in the linked model may not be active if you are not using worksets in your model.
