Hi all,
I have created about 10 levels in elvation but these do not display in the project browser, only the default levels (Level 1 and Level 2) are showing? Any ideas where I am going wrong?
Many thanks in advance
Luke
Solved by shiny.stephen. Go to Solution.
This issue could have occurred because you used copy or array while creating the levels. If you look at the color of the level marker you would see a difference. To have the structural plans created go to View tab- under create you have an option plan view- in that select floor plan and select the level you just created.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Just to clarify:
The "Levels" are not what are displayed in the Project Browser.
The *Plan Views* that are associated with the Levels (and, by default, named the same as the Levels) are displayed in the Project Browser.
Shiny explains how to create these default views.
Joe
