HI all
PLease help me link between Advance steel & Concrete 2015 With Revit 2015
In advance steel have Import revit, but in Revit not addin import .gtc file
If choose method *ifc file: in revit 2015 have Link IFC, but when I tried import *ifc file from advance steel. Then structure column not structural element
and When import ifc from revit into advance steel
It's not good
Please help me for workflow coordinate between Advance steel and Revit
Thank all
DarrenP
Thank Darren so much
Please guide me to mapping profile and material between Revit and Advance Steel & Concrete.
Thank So much
the mapping database is like a translation for the profile names between Advance and Revit.
The profile names and the material names need to be mapped, that Revit can evaluate /use the correct profile or material
comming from Advance (and vice versa).
The Advance Steel profiles are stored in a database (all profiels are available in new project by default).
Revit use the families to define the profile sections and not all families are loaded by default (depending on the template).
If a unknown profile is imported then the follwing dialog appear on the screen. You can load the family and select the matching profile.
Best Regards
Michael
There is now also a dedicated forum for Advance Steel online:
http://forums.autodesk.com/t5/Advance-Steel/bd-p/2056
regards Udo
